What oil to run in my 47 Farmall H?
Firecat400EX
01-30-2006 21:42:00
Hey guys, we have a 47 H that I would like to start restoring next year. Its in desperate need of an oil change and i was wondering what oil and viscosity i should run in her? Thanks!
NDS
01-31-2006 05:43:07
 Re: What oil to run in my 47 Farmall H? in reply to Firecat400EX, 01-30-2006 21:42:00
Every farmer I know switched to detergent oil at least forty years ago and I doubt that this tractor has been running on nondetergent. Do not know best weight but have seen a lot of tractors do a lot of work on straight SAE 30 in the South.
Nat 2
01-31-2006 06:32:50
 Re: What oil to run in my 47 Farmall H? in reply to NDS, 01-31-2006 05:43:07
If every farmer you know is still using CaseIH Low Ash 30W, then the joke's on them. It's a NON-detergent oil.
That's my recommendation. Use CaseIH Low Ash SAE 30 if the temperature stays above freezing. We always put SAE 10 in during the winter for easier starts.
NDS
01-31-2006 08:21:12
 Re: What oil to run in my 47 Farmall H? in reply to Nat 2, 01-31-2006 06:32:50
Did not know IH (long before New Holland/Case) sold motor oil before I read about it on this forum. Dealer probaly had motor oil but never remember seeing it and never knew of anyone using it.
billde
01-31-2006 08:08:30
Nat, if you check the specs on IH low ash oil you will find that it is 10 to 15 percent detergent. That is according to the oil specs and the msds sheets.
sammy the RED
01-31-2006 07:37:39
Case/IH Low Ash Engine Oils
For LPG, Natural Gas, and similar engines
A superior quality product blended for optimum performance and service life. Low Ash is specifically designed for heavy-duty service in agricultural, industrial, and construction equipment
Available in SAE 10W and SAE 30 grades.
Provides high level of dispersants (detergents) formulated to minimize metallic ash deposits, lengthening valve and spark plug life.
billde
01-31-2006 04:44:48
Drop the oil pan and clean it out, use 10w30 or 15w40 depending on how hard you use it. Detergent oil will keep the "dirt" in suspension and run it through the filter, keep an eye on the oil, don't let it get real dark.
jeffalex2
01-31-2006 03:23:17
Straight, non-detergent, 30W...if she hasn't been rebuilt before, DON'T run detergent multi-wt in it. 'Cause it'll break up the sludge, clog some ports, and you'll make more work for yourself when you do the restore.
