Which Oil
IronHorse
01-31-2006 08:37:22
What oil should I use in an U-240 gas power unit?
Farmallkid From Ont,
01-31-2006 17:06:38
 Re: Which Oil in reply to IronHorse, 01-31-2006 08:37:22
We use 15w40 In ours, they dont get used in the winter much, use them for parades and plowing. A guy I know uses 15w40, in everything from his cub cadet lawnmower to his 8940, Farmalls, A to 1486, and there ford gas and diesel pickups.
RickL
01-31-2006 16:41:45
10w30 period. have used it all my life and have yet to lose or overhaul any of the motors I have had. Car truck or tractor. Most important thing in my eyes CHANGE IT REGULARLY PERIOD.
RickL
01-31-2006 16:41:31
Nat 2
01-31-2006 12:35:33
CaseIH Low Ash SAE 30 in spring, summer, fall.
CaseIH Low Ash SAE 10 in winter, if it regularly gets below freezing.
No law says you gotta do it that way, just my humble opinion based on 30 years around gas-powered Farmalls. Opinions are like .... Well, you know. Everyone's got one.
Brownie 45
01-31-2006 10:14:36
I'm not a big fan of multi-viscosity oils, so below 10 degrees #10w. From 10 up to 40 degrees #20/20w. From there on up, #30. If temps are going to be above 80 degrees for extended periods, use #40.
RustyFarmall
01-31-2006 11:32:48
 Re: Which Oil in reply to Brownie 45, 01-31-2006 10:14:36
Brownie, I do tend to agree with you, but I also know the multi-viscosity oils are pretty good, especially for a tractor that will be used in all weather conditions. 10W-30 works good, 10W-40 is probably OK also, but I sort of draw the line at 5W-30. Just my opinion.
opp
01-31-2006 17:36:19
 Re: Which Oil in reply to RustyFarmall, 01-31-2006 11:32:48
I don't know why you guys don't like multi-vis oils, I haven't had anyone prove to me that a straight weight oil was any better. Oh, the 5W-30 is a better oil than the 10W-40. 10W-40 is probably one of the worst because of all the additive in it. As far as tractors, we have 15W-40 in everything gas or diesel.
