240 ute tranny noise
Darin in Nebras
01-31-2006 11:48:48
Is it common for a international 240 utility to make a whinning noise when in gear? It does it the worst when in high gear and going down the road. When sitting still, it doesn't make it of course. Thanks for the input. Darin
Marvin
02-01-2006 05:25:55
 Re: 240 ute tranny noise in reply to Darin in Nebraska, 01-31-2006 11:48:48
Mine does the same thing. It is only noticable in high gear.
chadd
01-31-2006 12:02:01
All older tractors make some noise in the transmission and rear end. It will never be as quiet as a car transmission because of the straight cut gears, but it shouldn't be loud enough to hurt your ears either. I guess I would say that a steady humm is acceptable. It may change a little under load, but it shouldn't really come and go at various intervals, it should be pretty constant. According to some people I have talked to, louder transmissions are caused by mixing new gears with old gears during a rebuild. Because they aren't worn in together, they make a little more noise. Don't know if that is true or not. . .
Darin in Nebraska
02-01-2006 07:23:21
 Re: 240 ute tranny noise in reply to chadd, 01-31-2006 12:02:01
Thanks you. I am not to worried about it then. Thanks again.
