Front end adjustment
Erik in WI
01-31-2006 13:08:04
Planning to spread out the front axle on my 826. Never been moved. Any one have any sure-fire tricks to making the proccess go smooth?
Thanks,
Erik
Janicholson
01-31-2006 13:32:39
 Re: Front end adjustment in reply to Erik in WI, 01-31-2006 13:08:04
Soak it in your favorite juice. I like PB Blaster.
Block up one side at the point where the smaller tube comes out, but on the bigger tube. Remove clamps and pinch bolts
Put a 1.5 ton (or so) comealong between the rear axle and the front spindle as low as possible so as to twist on the axle.
Pound chisels along the split to open the end of the tube.
Apply twisting force without bending anything permanently.
Apply hammer blows around overlap area.
Apply the blue flame farie with much dancing.
JimN
Allan in NE
01-31-2006 13:28:53
Erik,
It 'taint gonna go smooth so you can just get that out of yer head right now. :>)
Allan
