SMTA lights again
todd in ne.
01-31-2006 15:02:13
I ordered new sealed type lights for my smta that has the flat back style housing. The new light will not fit in the housing. Parts store can't find any thing either. Anyone know what will work?
todd in ne.
01-31-2006 16:21:40
 Re: SMTA lights again in reply to todd in ne., 01-31-2006 15:02:13
Thanks guys I'll give these places a try.
Paul Shuler
01-31-2006 15:38:23
I ran into the same thing on a Super C a few years back. I tried lights from everyplace I could find. None fit right. Marks tractors has them that work and fit right but they are a bit pricey. Can't remember what I spent a few years back but I was thinking around $30. Give him a call he will have them. He has an add in Red Power.
slifnom
01-31-2006 15:27:23
Use your grinder and make the sealed beam lighs to the configuration of your light case.
al bane
01-31-2006 15:13:42
I have had two tractors with the flat banck lights and I replaced them with sealed beams from Tractor Supply and they worked fine. The tractors were Farmall 300 and 400 --12 volt.The same sealed beams also come in 6 volt.
todd in ne.
01-31-2006 15:23:55
 Re: SMTA lights again in reply to al bane, 01-31-2006 15:13:42
I have tried the parts stores and they can't come up with one that will fit. Our farm store only carries a few lights.
slifnom
01-31-2006 15:11:41
Brian Schmidt
01-31-2006 16:23:46
 Re: SMTA lights again in reply to slifnom, 01-31-2006 15:11:41
I would like to see that!! I tried it on a cheap one from TSC and it shattered when I got close. Maybe you have a watercooled jewlers grinder, but I don"t.
randy hall
01-31-2006 19:23:04
 Re: SMTA lights again in reply to Brian Schmidt, 01-31-2006 16:23:46
i us the available lamp and wrap about four times with electric tape instead of useing the thick rubber gasket. save money, have lights.
