smoke and poppin 460D
Gary in Mozarks
01-31-2006 17:00:13
Im here askin advise again, (you all have always been on the money when it comes to advise) My 460D has gotten harder and harder to start when its cold and it blows white smoke most of the time, which is gradually turning darker. Now its started popping out the exhaust. It started out once in a while but its popping more and more now. A friend suggested that it has one or more burnt valves and its time to redo the head. Any thoughts on that subject? Thanks in advance Gary
Jimmy King
02-01-2006 02:00:03
 Re: smoke and poppin 460D in reply to Gary in Mozarks, 01-31-2006 17:00:13
Just a question Gary does the starter turnit over very fast when trying to start. My 460 got very hard to start one time we had the starter over hauled and it was like a new tractor after that. It should turn over almost like it has no compression.
Jimmy King
02-01-2006 01:59:22
Jimmy King
02-01-2006 01:57:23
Jimmy King
02-01-2006 01:57:04
Jimmy King
02-01-2006 01:55:35
Jimmy King
02-01-2006 01:54:28
billde
01-31-2006 17:36:38
Try running a real stiff charge of Sea Foam mixed in with the fuel. It will help get rid of carbon, and clean your injectors. The 460 is noted for poor winter starts. Are all of your glow plugs working?
Gary in Mozarks
01-31-2006 19:09:29
 Re: smoke and poppin 460D in reply to billde, 01-31-2006 17:36:38
I checked the injectors about a year ago and replaced two that were bad but I havn;t checked them Recently. I will try the sea foam tomorrow Thanks
old
01-31-2006 17:13:34
Could be valves or it could be you haven't been working it hard enough. You may have carbon bluid up in it. But thats just my guess.
