Wide front options
Kenny Ehlmann
02-01-2006 16:34:45
Thinking of putting a wide front on a Farmall super C, other than the factory option, are there any aftermarket kits that will fit, was also thinking of using one off of an Farmall A or Cub. Thanks in advance
Jim Becker
02-02-2006 07:26:32
 Re: Wide front options in reply to Kenny Ehlmann, 02-01-2006 16:34:45
To use an A axle, I would keep the C steering gear as it is and fabricate a bracket that bolts to the bottom of the bolster and provides the axle pivot. Use an existing C wide front as a guide. You would also need to make a center steering arm.
I think you would still have to want a wide front pretty badly to go through all the work.
gene bender
02-02-2006 00:46:19
The one for an A would require moving the steering from left side to the right side and wouldnt be hard to do. Forget CUB it wount fit and would also be to flimsy.
CNKS
02-01-2006 17:54:15
I don't know if Swartz, etc makes one for the C or not, they probably do. Cub or A will not fit without more modification than you want to do, unless you want a conversation piece.
