Farmall A Engine Rebuilding
DJ in NH
02-01-2006 16:59:06
I have a Farmall A that I plan on restoring soon which will require a engine overall. I have a couple of questions which I would appreciate any input from you guys.
1. I have read the add for the Tisco kits. Have any of you bought these kits and have you been satisfied with them ?
2. The kits are availale with stepped pistons. If the engine now has flat pistons can you switch to stepped pistons and if so can you expect any real difference in performance. Does any additional work need to be done to the head / valves to accomodate the stepped pistons.
3. Last question. Have any of you had your engines balanced and did you notice any real improvement. I spoke to a local shop today that has been aroud a long time with a great reputation. The cost is around $ 250 for a 4 cylinder gas engine. The fellow told me don't expect any real gain in H.P. but the engine will definitly run smoother. I relize that a Farmall A isn't exactly a big block racing engine but I plan on keeping this tractor for a long time and really want to do right. Thanks guys for your help.
Georgia Boy
02-02-2006 08:59:00
 Re: Farmall A Engine Rebuilding in reply to DJ in NH, 02-01-2006 16:59:06
I finished rebuilding a 1946 A this past summer, so my answers are...
1. I bought the domed TISCO piston kit from this site, so far the old girl runs great.
2. The head on the A was built to accomodate all variations of pistons and needs no alteration, unless it has been shaved flat too many times.
3. My reading showed that balancing an A engine wasn't worth it, unless you have the money.
El Toro
02-02-2006 05:14:19
I would agree with Gene and Dave on balancing that engine. It would be a waste of money. When I restored a Farmall A 30 years ago I used
a kit from my local IH dealer. I did use the
3.125" sleeve kit. It had enough power to make the new tires to slip when plowing sod. That was a 16-inch moldboard plow too. The sleeve kit
was only $80.00 back then. Hal
Red Dave
02-02-2006 03:17:45
I'm in the middle of rebuilding a B engine, (which is the same engine as an A). I bought my kit from the local NAPA and it is a Clevite kit. I don't know anything about TISCO.
My kit is 3 1/8, high compression pistons and no modification to the head is required. The raised top on the piston is shaped to fit the head, as long as you get them in facing the right way.
Fire Crater is the IH brand of higher compression pistons, and I know that they are still available from a Case/IH dealer. If you are worried about proper fit, you could go with them as they are factory official replacments.
A Farmall A already runs nice and smoothly with a stock crank. Balancing a 1500 RPM engine seems like a waste of time and money to me.
gene bender
02-02-2006 00:40:57
There are lots of kits out there and price differs. Buy from a place that is going to be there if you run into trouble. Balancing an A FARMALL engine would be just a waste of good money but you do as you like as its your tractor. Have you tried your local CAR QUEST dealer for a kit?
