WD-9 gasket problem
BT in NE
02-01-2006 18:05:04
Hey guys, I have been lucky enough to find a good head for my tractor, but I do need some help with the gaskets. My tractor has been bored out to the 350 cid engine. Trouble is, none of my parts sources say their gaskets will work on a 335 converted to a 350.Why and what would you guys recommend I do? I don't really like the idea of getting everything ready to go and then not being able to put it together. Thanks a million. BT
justin w
02-02-2006 13:55:25
 Re: WD-9 gasket problem in reply to BT in NE, 02-01-2006 18:05:04
I can get the correct head gasket, but it is not cheap. The WD9s with the IH 4.5" overbore kit require a special head gasket, as the sleeves do not stick up above the block height. This requires a head gasket with a built in fire ring.
P Backus
02-01-2006 21:47:55
In addition to what El toro said, the SWD-9, 600, 650 all had the 350.
Paul
El Toro
02-01-2006 18:40:08
Would the headgasket from the IH 650 or the TD-9
fit your engine? They both have the 350cid engine. Hal
