welding m sleeves
m-restorer
02-01-2006 18:20:18
im going to weld the sleeves out on my m.do you weld up and down the whole sleeve?how many weld beads should you have to make on each sleeve for it to come loose?
champspa
02-02-2006 13:18:46
 Re: welding m sleeves in reply to m-restorer, 02-01-2006 18:20:18
mine after 2 beads with a mig welder pushed out with a stick
champspa
02-02-2006 13:18:19
mine after 2 beads with a mig weldet pushed out with a stick
Mcred
02-01-2006 21:50:46
how are you guys "welding a sleeve out" just courious, soundes like it could be kinda handy.
Kelly C
02-01-2006 20:58:46
Unless you are a good welder I dont recomend it.
Way to easy to make a mistake and mess up the block.
I tried on my 706 and was not happy. Put 3 beads along the inside and could put hand in and it still felt cold. Block is a big heat sump. put the 4th bead down and cut though the sleeve rod stuck to the top of the sleeve and tapped the top of the block as I wiggled it off.
After that some thing got hot but it was not the sleeve. Amazine how much the price of those elctrodes has went up since the last time I had to buy one :-)
Took a bit of work for me to fix that mess.
Then again I have watched some one who knows what they are doing do it. He was in and had the sleeve out lickity split.
I guess I need practice.
roy prins
02-01-2006 20:20:23
when welding sleeves out weld fast startingat the bottom and pulling up if you blow thru the sleeve you could damage the block. i do 4 beads and out they go
IHnut
02-01-2006 18:31:05
I run 5 or 6 beads starting from about an inch from the bottom to about a half inch from the top.
