Road Rims for Farmall Regular
Tom Windsor
02-01-2006 21:04:20
There is a photo on this site of a 1925 Regular. It has rims over the steel lugs for road use. Does anyone have information on these rims. If they are available, where etc.
Kevin LA-CA
02-02-2006 05:28:09
 Re: Road Rims for Farmall Regular in reply to Tom Windsor, 02-01-2006 21:04:20
Tom
I had posted photos of my 1927 Regular with road rims a few months back. If you saw these - they were shop made.
I measured the OD - lug to lug - and had a steel shop roll the rings. For the rear I used 1/8"x4". Next time 3/16". I made a clamp for the ends from angle and 1/2" bolts to tighten. I cut lug high lengths of 1" steel pipe. Then I bolted the ring through the pipe spacers and holes in the wheel. The spacers allowed me to cinch it down tight. Then bolted a strip of old tire lug over the top.
I can send photos if you like. kevin
JohnG(TX)
02-02-2006 14:09:43
 Re: Road Rims for Farmall Regular in reply to Kevin LA-CA, 02-02-2006 05:28:09
Kevin,
Could you also send the photo to me
jhgold@stic.net
Thanks.
Windsor
02-02-2006 07:39:52
Kevin
Yes i would appreciate pictures. Twindsor@aol.com
John in Ne.
02-01-2006 22:33:01
I have a neighbor who has a set on a JD GP.He said his came with the tractor when it was bought new by his uncle. I would think that a well equipted welding shop could build a set.His are about 1/2" x 2 1/2" and are on skeleton wheels. John.
