engine for a w-40 McCorrmick (1938)
mi mark
02-02-2006 07:26:59
a friend of mine is looking for an engine for a 1938 w-40 McCorrmick-Deering if anybody can knows of one it wood be greatly appreciated thanks
randy hall
02-02-2006 17:09:20
 Re: engine for a w-40 McCorrmick (1938) in reply to mi mark, 02-02-2006 07:26:59
i am going to have some extra w-40 parts if you aren't in a big hurry. i have two w-40's to make one.
russ hamm
02-02-2006 10:52:47
my w-40 has a red diamond international truck engine in it, i forget which one.the tractor governor and clutch will fit on these. there are several red diamond engines and this appears to have been a common thing to do to get some more horsepower out of an already good horse tractor. i have seen some even run the truck distributor and this is really dependable.mine has the tractor governor so we run a mag.i think our engine is a 504? 450 red diamonds are common.if you have the original block for the tractor governor keep it! the tractor starter has to be used as the truck starter will not fit but we have made some w-9 starters work bolted in at an angle (kind of wrong but it works!).the tractor water pump also needs to be used, but i did adapt a truck fan and water pump with a plate and some engineering.so boys, keep those bad engines for parts and you can put in the good truck engines that look like original. a friend of a friend said that his dad got a brand new w-40 with a truck engine in it in leu of the tractor engine in the late 30's. could be.
JonT
02-02-2006 08:16:43
I"m looking for an engine for mine as well. They used the FAA Truck engine, so if you can find a 30"s vintage IH truck, D-5 or D-6 or bigger,that will work, manifolds and governor will be different though.
