300 crank-rod journal /any one seen this ?
RICK/OASIS IDAH
02-02-2006 13:57:09
I finished tearing down the 300 (c169) today and as i suspected from the hard knock she had the #1 rod bearig was completly gone. To my suprize when I got the pistons and crank out what do I find to my surprize there is not a mark or scoring grooves ect on the crank or the rod. This motor was ran several hours 10 to 12 at least with this rod knocking. I realize I still have to mic the crank and rod end but i am schocked there is no visable damage. Anyone every see this before. Who knows maybe lady luck is with me.
Rick/Oasis Idaho
02-03-2006 07:27:32
 Re: 300 crank-rod journal /any one seen this ? in reply to RICK/OASIS IDAHO, 02-02-2006 13:57:09
I'm doing a complete overhaul, taking the head,block crank cam ect t o the machine shop tommorow. we will hot tank the block,magniflux it and the head, new sleeves, bearing, crank and cam,pistons,liners,ect ect....of course we will mic everything and repair/ replace as necesary. I just have never go like this and not do visual damage. thanks for the input
Ron in Nebr
02-02-2006 18:13:53
If you really do get lucky and the rod journal on the crank mics ok AND the inside of the big end of the rod checks out too(do check both) you might have come out pretty good.
But, it might be wise to find out for sure why that happened, especially if all the other bearings are good(I"d check a couple of the others while you have the pan off). I"m not familiar with the oiling system on those engines, but if the crank has drilled oil passages to lubricate the rod bearings like cranks in other engines, you might have something plugging up the oil passage to that journal. The plugged oil passage would be the problem, the wiped out bearing is just a symptom. Better to cure the problem than the sypmtom, or else you"ll get alot of practice changing bearings, and sooner or later it WILL take out the crank and rod.
RICK/OASIS YDAHO
02-02-2006 17:23:04
 correction in reply to RICK/OASIS IDAHO, 02-02-2006 13:57:09
Sorrry i typed before i thought. It would be #4 cylinder 1st one from the rear, and the bearing was complety gone.
Fred F
02-02-2006 14:25:31
the cam gear is not tight on cam
MagMan
02-02-2006 14:15:48
I will tell you what I have seen people tear down motors with knocks in the front of the motor and have it be the waterpump that was knoking. I have heard of this and done it my self on an M. put her back to gether and use a broom stick or stephascope to see if thats what it is. JON
RICK/OASIS IDAHO
02-02-2006 14:22:36
 Re: 300 crank-rod journal /any one seen this ? in reply to MagMan, 02-02-2006 14:15:48
It definetly was the # 1 rod bearing, you could grab the rod and rattle it around on the crank and when tore down the bearing was not there. With that said it could have a bad water pump as well but the knock was at the rear of the engine
Janicholson
02-02-2006 14:46:45
 Re: 300 crank-rod journal /any one seen this ? in reply to RICK/OASIS IDAHO, 02-02-2006 14:22:36
#1 is by the radiator!!
That said, was the shell of the bearing in the rod?
and all the soft material in the pan!!!
Mighty wierd to me.
JimN
