1939 Farmall F-30
Martin Nafziger
02-02-2006 23:28:54
I'm thinking about buying an F-30. The owner said he had a dealership look up the SN and it was a 1939 model. Said when he parked it the engine was shaking so bad that things were shaking out of the toolbox and the clutch was slipping. It's been sitting outside for 10 years, rubber is shot, but the rims seem ok, hood had been cut on, ex. manifold was un-covered so water surely got in the engine. block isn't cracked though and he said he had drained the coolant. He also said it had an overdrive and the optional spring/shock absorber seat. How hard is it to find parts for these tractors, and what is it worth??? I don't want to put money in it and then find out i can't get engine parts, etc... Thanks, Marty
Martin Nafziger
02-03-2006 21:41:52
 Re: 1939 Farmall F-30 in reply to Martin Nafziger, 02-02-2006 23:28:54
He want's $650 for it and I thought that was pretty steep for how bad of shape it was in. I doubt he'll come down much on it as it was in his family for quite awhile, and i don't think he really wants to see it leave. So it looks like it will set there a while longer. Thanks for the input! -Marty
russ hamm
02-03-2006 05:06:30
marty, those tractors should be pretty cheap in that condition.if un stuck it would be a diffrent story. if he is over 500 dollars then keep looking. if he is 100 or 200 then you can afford to look for parts. some can be stuck really bad on all 4. the vibration he described is not good.you can find a decent f-30 in running condition sometimes for 1200.00 on up.
Nebraska Cowman
02-03-2006 03:07:07
It won't be cheap to fix but parts can be had.
