Re: 560 questions
Janicholson
02-03-2006 16:24:48
I'm going to answer some of the questions as best I can with what I know.
If you are pulling the tractor, the amount will be different depending on what you remove to reduce parasitic drag.
Use #00 wires for the battery cables with soldered on ends. Use 10 gauge wire for charging system current loads and the alternator. Use 12 gauge for all else. Use different colors, follow the original color scheeme to prevent hazardous throwing of things in frustration. Use crimp on terminals and shrink tubing to detail the terminals and limit moisture and bending related breakage.
JimN
Mcred
02-03-2006 16:27:42
 Re: 560 questions in reply to Janicholson, 02-03-2006 16:24:48
thanks, Jim
Broomstacker
02-03-2006 17:19:43
 Re: 560 questions in reply to Mcred, 02-03-2006 16:27:42
McRed, my book says the 560 holds 16 gallons of Hy-Tran, regardless of whether it has a T/A or Hydra-Touch.
Mcred
02-03-2006 17:33:46
 Re: 560 questions in reply to Broomstacker, 02-03-2006 17:19:43
thanks Broomstacker for taking the time to look it up. Justin
