PRICE SUPER C
CHARLIE H
02-03-2006 20:08:15
WHAT IS A SUPER C WORTH THE MOTER IS STUCK NEEDS MANIFOLD THE HOOD IS GREAT SHAPE NO DENTS BUT FRONT GRILL IS LITTLE PUSHED IN . RIMS ARE IN GOOD SHAPE TIRES ARE BAD BUT HOLDS AIR BUT NOT SURE RIGHT SIZE . HAS QUICK HITCH TRACTOR NEEDS PAINTED SAT FOR COUPLE YEARS . GUYS ASKING $700.00 WHAT DO YOU THINK?
gene bender
02-04-2006 17:23:07
 Re: PRICE SUPER C in reply to CHARLIE H, 02-03-2006 20:08:15
Not a bad price it would part out for a lot more than 700.
El Toro
02-04-2006 16:58:45
I would check the radiator to see if there's
an antifreeze mixture visible. You don't want to
end up with a cracked block. The radiator could've been drained, but that doesn't mean they drained the block. I think $500 would be top dollar to pay for it, I would offer less and see what the owner has to say. You can always come up in price with a counter offer. There're
really a nice tractor. Hal
old
02-03-2006 21:16:50
In that condition I would say scrap price. Probably $200-500, 500 is top $$ for it and thats probalby high unless it has some implaments with it
Jim Broughton
02-03-2006 20:22:29
Price sounds a little high to me, unless it has some equipment to go with it. Bare tractor in that condition would be worth about $450.00 to $500.00. Bear in mind, you've got to "unstick it", most likely you will have to either re-build or at least overhaul it, replace the tires and all the other stuff to get it in first-rate condition. Gobs of work and MONEY!! But, it sure would be nice to hear her run again! Lots of luck on'er! Jim
