Super C lights
Mike D
02-04-2006 18:25:48
What would cause a light on a super C to not work on either side of the light bar? The right one works on the right but not on the left,and the left doesnt work on the left or right and it is brand new. I thought that from someone welding on the light bar from before i got it ,maybe burned a hole in the wireing caseing and was shorting it out ,but on a early post i was told that that would not burn a sealed beam out. The tractor is 6 volt and i bought 6 volt lights. I have been trying to get the light bar out but it must be rusted in. I took out the two set screws on the light bar so i think it comes out in two pieces ,but was told it is all one piece. I did put PB blaster in the set screws to soak for a few days,so will see how that works.
I"m Not shure why the light on the left is not working other then maybe the wire is broke or something. Any ideas i could look at would help, THANK"s
Janicholson
02-05-2006 08:39:28
 Re: Super C lights in reply to Mike D, 02-04-2006 18:25:48
If there is a bad (disconnected or internally broken wire in the bar), Here is your fix!!!
Get a bicycle rear gear change cable (not the plastic part, just the stranded inner cable, used is great)
Find the wires coming out of the light bar near the post, and clean the tape and whatever insulation is on them so the wire is bare for 1/2" going to both lights (do not pull them out)
Use a blue crimp tube (electrical connector that joins two 12 gauge wires with a crimp pliers).
Remove the blue plastic insulator and use only the metal sleeve.
Crimp the end of the bike cable into one end of the connector and the wire going left into the other. Be firm with the crimp tool (if you do not own one buy a 8-10 dollar plier, not cheap, you need it any way).
Pushing on the bike cable while simultaneously pulling and finessing, wiggeling and flexing the lamp end will snake the old wire out. Put a new piece of #12 wire on the cable using the same method but a new crimp sleeve.
Pull one end, and push the other till through the hole. Do not force anything, pulling the wire in half will cause fishing.
Do the other side the same way.
Put crimp connectors and eyelets on the wires to fininsh the job. I like to put 1.25" of shrink tubing over the crimp connectors to add strength and for finnish.
Good luck, JimN
Peabody
02-04-2006 20:27:17
Sounds like you've got a ground problem and a burned out "left" light (even though it is new). The ground problem is probably either between the light fixture and the light bar (remove fixture from the bar and sand the bar and inside of fixture mount for good ground) or inside the light fixture. Or possibly a dirty or bad connection at the seat for the bulb itself (sprung spring). There is a brass ground tab inside the fixture that must be making a good, clean contact to the fixture housing for proper ground. This is assuming you have the original "bullet" shape fixture, not the flat type sealed beam fixture. A cheap multimeter to check for continuity is really helpful here, can be bought for less than $10.
twincreeks
02-04-2006 18:38:07
Try cleaning the light bar with a wire brush, and check the wires going to the light.
Yugrotcart
02-04-2006 18:37:24
Try the working light on both side, if one side doesn't work, either bad ground or broken wire..... ...
