S/C Bearings
S/C Bob
02-05-2006 04:36:18
Could someone give me some instructions on replacing the bearings on my S/C`S generator.It still charges ok but the bearings are noisy.. Thanks in advance. Bobby
Haas
02-06-2006 06:56:42
 Re: S/C Bearings in reply to S/C Bob, 02-05-2006 04:36:18
I always take mine to a starter/generator shop.
Janicholson
02-05-2006 08:01:07
The bushing and bearing come out easily (as Gene noted). The use of a square edged socket (I buy a cheep bunch of sockets from the pawn shop and grind the edges to square them up, to use as a set of drivers)to drive the bearings out and in works well.
Do not pound on them (especially in the shield/seal, ou on the inner race of the ball bearing.) Brass hammer, perfect alignment to go in straight, and tenderness. It will go smoothly,
JimN
gene bender
02-05-2006 06:43:03
There is a bearing on the pulley end and bushing on the other end and are easy to replace. Just take it apart. Mite need to make a new gasket for the bushing end where the wick oil system is used.
