pulling crank pulley off of C 113 engine
james54@iocc.com
02-05-2006 11:36:38
What is the best way to get crank pulley off Thanks for any help
El Toro
02-05-2006 13:09:22
 Re: pulling crank pulley off of C 113 engine in reply to james54@iocc.com, 02-05-2006 11:36:38
You need to make one these puller's. It was designed for a Cub, but with a slight modification
on the cutout and hole spacing it should come off with very little effort. Hal
PS: A metal shop will charge arout $50.00 to make this.
http://www.ytmag.com/farmall/messages/459316.html
glenster
02-05-2006 12:29:35
when i did the overhaul on my farmall b, i soaked it up good with pb blaster, then used a puller with a bearing clamp. you may need to put a little heat on it too.a propane torch will work. after you get it off check the seal area for wear, if it has a groove worn it you can get a speedie sleeve to put on it, cheaper than a new pulley. also to get it back on, i heat it up in a presto fry daddy deep fryer. (my wife was mad as h*ll but it works good) i used regular cooking oil and it slid right on. good luck!
