O-6 Suffix
Andy Martin
02-05-2006 14:43:53
Serial number OBK 26319 W1B.
What is W1B (or WIB)
CNKS
02-05-2006 17:21:23
 Re: O-6 Suffix in reply to Andy Martin, 02-05-2006 14:43:53
X1B is gasoline with 5000 ft attachment. Guy's book does not list W1B. There is a W1K which means battery ignition, hyd pump drive, starting and lighting. Another is W12B pneumatic tires, swinging drawbar, starting and lighting. But, I bet it is W13 which means swinging drawbar.
Dave Slater
02-05-2006 17:55:22
 Re: O-6 Suffix in reply to CNKS, 02-05-2006 17:21:23
CNKS,I looked at Guys book after your reply.At top of page it reads use X for farmall,W for W series or Y for industrial.
CNKS
02-05-2006 19:49:24
 Re: O-6 Suffix in reply to Dave Slater, 02-05-2006 17:55:22
OK, I didn't read the instructions, at least not recently, I apologize. I suppose the reason was that all the W options on the W and O series were not used on the letter series and vice versa. Andy is the first to ask about a code on a W or O series on this board that I can remember -- been reading this since 1999, have had the data book that long also -- learn something every day, I guess.
John M
02-05-2006 17:50:03
X was used on the Farmalls, W was used on the W and O series(McCormick Deerings) and Y was used on Industrials (Internationals).Just substitute the letter for the right tractor.
Dave Slater
02-05-2006 15:01:54
Gasoline fuel with 5000 ft. altitude equipment.
Andy Martin
02-05-2006 15:27:00
 Re: O-6 Suffix in reply to Dave Slater, 02-05-2006 15:01:54
THANKS!
