Oil filer on Farmall Regular
Tom windsor
02-06-2006 13:31:26
Does anyone have a picture of the oil filter on the Regular and where it is mounted on the tractor?
pgo12
02-06-2006 13:50:20
 Re: Oil filer on Farmall Regular in reply to Tom windsor, 02-06-2006 13:31:26
it is mounted to the left of the mag, but higher,[towards the back of the tractor]. if your block is set up for one, there are 3 holes for the screws that hold the base. pg
Nebraska Cowman
02-06-2006 13:49:58
the later Regulars and F20 had the filter mounted at the upper rear of the block, right hand side. The early Regular like yours never had a filter. you have the oil pressure guage mounted at the front above the magneto drive, Right?
