300 wire harness
Levi Keech
02-06-2006 15:44:36
Hafta rewire the 300, and I was wondering; how to rewire it with out the voltage regulator it has been changed from 6 volt to 12 volt and the guy how did it just stripped back wires on the regulator and tapped it in to the wires on the one side but now it has been changed can the regulator be eliminated???
El Toro
02-07-2006 05:22:32
 Re: 300 wire harness in reply to Levi Keech, 02-06-2006 15:44:36
Are you using an alternator or generator? Some alternators have internal regulators and no external regulator is required. Generators require a regulator. If your tractor has an alternator without an internal regulator it will need a regulator. Hal
