timing a M
1951M
02-06-2006 16:44:40
im doing a inframe rebuild on my M.i need to know how to get it timed rite when i put it back together.i have taken the distributor out where it connects to where you dump the oil in
El Toro
02-06-2006 19:06:29
 Re: timing a M in reply to 1951M, 02-06-2006 16:44:40
You need to bring No1 piston up on the compression stroke to TDC. Have someone hand crank the engine while you hold your over thumb over the sparkplug hole until you feel pressure
against your thumb. When you feel this pressure
look for the notch on your damper pulley and slowly keep cranking the engine until the notch
is aligned with the pointer. The engine should be
at TDC on the compression stroke.
Rotate the rotor in the distributor to the No1
plug tower and install on the engine. Hal
Stacey Austin
04-20-2006 11:35:54
 Re: timing a M in reply to El Toro, 02-06-2006 19:06:29
do you have to do anything with the magneto? And also what is the points gap supossed to be set at?
