Re: Farmall M Radiator
jal-SD
02-07-2006 10:59:48
Early H's & M's had the non-pressure type. Later ones had pressure types. No difference in guages. Find a good one @ the nearest salvage yard for an M & put it on. Make sure you adjust it so the sterring shaft goes through the center of the hole in the radiator and you should be good to go. We used to use folded up scrap inner tube ruber on the bottom of H radiators to get the height right, you'll need something like that to prevent metal-to-metal contact on the bottom. There is some r to l adjustment in the mounting holes on the front bolster. (My $0.02 worth. jal-SD)
