300 overhaul kit ?
RICK/ OASIS Ida
02-07-2006 13:08:01
I have looked at prices on this web site for a complete top n bottom kit w/ bearings. I also will need a crank and 1 rod, Anyone suggest another place to compare prices with.Thanks Rick
DEWAYNE UTRUP
02-08-2006 09:22:57
 Re: 300 overhaul kit ? in reply to RICK/ OASIS Idaho, 02-07-2006 13:08:01
RICK, I HAVE A REAL GOOD SET OF USED SLEEVES AND FLAT TOP PISTNS. THREE SLEEVES MEASURE .0005" WEAR AND ONE HAS .0015". THE PISTONS SHOW NO MEASUREABLE WEAR. I AM OVERHAULING DAD'S OLD TRACTOR HE BOUGHT NEW AND WE MADE A CONCIOUS DECISION TO PUT EVERYTHING IN NEW. EMAIL ME IF YOU WOULD LIKE TO DISCUSS.
Mike S 806/H
02-07-2006 20:44:12
Look on Ebay there is a guy on there that sells new sleeve and piston kits, he is reasonable priced, Im going to buy a set from him
Kelly C
02-07-2006 19:31:22
Hey!!! dont forget to try your IH dealer for the sleeve kit.
I priced kits all over the place for my 706 and got mine from my dealer for at least $100 less than any one else and I didnt have to pay shipping.
Might want to wait on the bearings until you have a crank so you can get the right size.
Jim J
02-07-2006 17:48:27
I would have a used crank and a rod.
MagMan
02-07-2006 16:27:19
If you give me your email I will give you my A&I prices They may not be the same as another dealer and And I will not post them here becuase there against my YT board morals. JON
RICK/OASIS IDAHO
02-08-2006 05:22:53
 Re: 300 overhaul kit ? in reply to MagMan, 02-07-2006 16:27:19
e-mail is ls57racer@aol.com engine is c169 w/ firecrater pistons. tractor serial # is 11711. I will need complete kit including the top end valves ect. For the person posting he has a crank and rod how much and is it standard or does it need to be ground and polished. I will need to check the rod pin size, they made 2 for this motor.
Thanks again guys Rick
Janicholson
02-07-2006 13:33:35
NAPA, And other Professional level autoparts stores, will work to supply the parts.
JimN
