Wrong fuel pump, 400D??
Farmall Frank
02-07-2006 13:16:25
third party image
I think I have the incorrect pump for my 1956 400D. This one does not have the air filter line, etc., and the primary pump only has two ports instead of three. Is this the "A" pump when it should be a "B"?
This tractor was used for two years in highway construction, I am told, before coming to my dad, so anything could have happened, I guess.
Dave Slater
02-07-2006 14:59:17
 Re: Wrong fuel pump, 400D?? in reply to Farmall Frank, 02-07-2006 13:16:25
Thats type B pump, if your engine # is high enough it may be original.If not original IH sold pump # 270000 R91 to replace the original pump.
Lot of 400 have been changed.Your B pump should have a drain tube on bottom.
Farmall Frank
02-07-2006 15:13:08
 Re: Wrong fuel pump, 400D?? in reply to Dave Slater, 02-07-2006 14:59:17
And it does have the drain tube, so it is a B. Thanks.
