coil resistor
thumbanger
02-07-2006 16:07:28
How do I hook up coil resistor on C Farmall putting 12 volt batt have new 6 volt coil dont want to burn it up. Any help thanks
John T
02-07-2006 16:20:57
 Re: coil resistor in reply to thumbanger, 02-07-2006 16:07:28
The Ballast Resistor wires in series in the Ignitions Primary Circuit AFTER the Ignition Switch (its IGN output terminal, hot when ON) and BEFORE the input to the Coil, being the coils lil input (NOT to distributor) terminal. That way when the Ignition is on and the points are closed, it draws current and drops approximately 6 volts, leaving 6 on the coil as it was designed for. That way the coil dont overcurrent and overheat and the points switch the proper current so they last as they should.
I like to mount the ballast where its somewhat protected from damage and direct rainfall and secure its mounting clamp to metal of the tractor to help transfer heat away from it. They would ideally be near the same resistance of the coil but many off the shelf are like 1.5 to 1.85 ohms and 25 or more wattas, wirewound power units in a ceramic bathtub enclosure.
John T
captaink
02-08-2006 07:17:20
 Re: coil resistor in reply to John T, 02-07-2006 16:20:57
I like to change the switch on the starter to one that has a small terminal on the side that delivers current when the starter is running. I run a wire from there to the coil side of the resistor. That way I have a 12 volt start 6 volt run setup and it compensates for the voltage drop when the starter is engaged. I know on a C this isn’t a lot, but when you get to an M and it’s -20 F it becomes a big deal.
thumbanger
02-07-2006 16:35:22
 Re: coil resistor Thanks John T in reply to John T, 02-07-2006 16:20:57
Thanks John T for info love this site.
kfox
02-07-2006 21:17:04
 Re: coil resistor Thanks John T in reply to thumbanger, 02-07-2006 16:35:22
When I go to the autoparts store, I ask for a ballast resistor for a 85 6 cyl Dodge pickup. There is a 1/4 inch hole on the right side on the gas tank mount that used to hold a little bracket for the shutter control rod. Makes a good mounting place.
