h tag idetify
bobbys toy
02-07-2006 18:31:20
I have seen alot of H's with X1 onthe serial tag,I'm told the X1 stands for an small warm up fuel tank for distilate fuel use. I recently saw one with a tag that read X1A, What do'es the "A" stand for Thank's
RD/oh
02-07-2006 20:01:17
 Re: h tag idetify in reply to bobbys toy, 02-07-2006 18:31:20
I just got an H witha X1 on the tag and it has the small tank and hood for it. I don"t know what might have been changed since 1946. But X1 stands for gas only
IA Dutchman
02-07-2006 19:30:21
I think that the X1A stands for a gasoline engine with low speed gears.
CNKS
02-07-2006 19:29:53
The A suffix means it has a low speed 1st gear.
RustyFarmall
02-07-2006 19:17:47
You've been informed wrong. The X1 indicates a gasoline only tractor. This tractor will not have the small starting tank. I am not certain on the A suffix, so I won't guess.
kfox
02-07-2006 21:07:49
 Re: h tag idetify in reply to RustyFarmall, 02-07-2006 19:17:47
Many of the old Farmalls that were origionally distillate, were converted to straight gas engines and the X1 was added to the serial #. I have two like this. Both still have the distillate heads with the part #s ground off with a grinder and the gas head part # hand stamped on the side of the head.
williamf
02-08-2006 04:12:04
 Re: h tag idetify in reply to kfox, 02-07-2006 21:07:49
Wow. What's left to believe?
It would be just like people to do that. How are we going to keep all this stuff straight? They're just trying to start trouble. Wm
