H starter rebuild
Joe E
02-07-2006 18:40:25
Can someone tell me if there is a bushing in the end cap of an H starter? It has a wick oiler so it wont have one, right? I do see the one in the nose cone though. Thanks.
captaink
02-08-2006 07:09:54
 Re: H starter rebuild in reply to Joe E, 02-07-2006 18:40:25
Yes there is. To get it out I usually thread a tap into the bushing, clamp the tap in a vice and then gently tap the cover away from the vise being very careful not to break it.
The bushing should not have a hole in it, that way you can install it, and simply drill the hole out thought the oil hole and reinstall the wick.
kfox
02-07-2006 21:02:12
Yes there is a bushing in both ends. The brush end has a plug covering the bushing. (should have a plug)
Joe E
02-07-2006 19:01:39
Thanks Rusty. I sure dont see the old one though. Will new one have hole in it for the oiler or will i have to drill a hole? Thanks again.
RustyFarmall
02-07-2006 19:12:14
 Re: H starter rebuild in reply to Joe E, 02-07-2006 19:01:39
I don't remember for sure. Might be easier if you had to drill the hole. Wouldn't have to worry about getting it lined up that way.
RustyFarmall
02-07-2006 18:48:03
Yes, there is a bushing in both ends.
