HEY Allan in NE
tn terry t
02-07-2006 20:07:14
HEY ALLEN!!!!! I dont care what anybody says ! YOU DA MAN! those pictures you posted earlier on the charlynn steering where just exactly what i needed man! since seeing those, i have almost got mine hooked up. every picture that i have seen prior to yours had the line manifold turned to the other side mine just wont work that way. one more question if i may. what position do i need to have thw wheels turned before i drill that hole in the steering rod or does it mater thanks very verry much terry t
Allan in NE
02-08-2006 03:21:42
 Re: HEY Allan in NE in reply to tn terry t, 02-07-2006 20:07:14
Hi Terry,
Glad ya got 'er,
It doesn't matter where it is at because the motor uses the tractor's original steering stops.
Without a load, the motor will turn forever in either direction. So, just poke at hole in your shaft and you should be good to go.
Allan
