Re: 1941 MODEL A POPPING THROUGH EXHAUST . HE
kevin billups
02-08-2006 13:10:50
I found that when i pulled off the valve cover that adjuster on exhaust valve on #1 had backed off far enough that the push rod had had slipped past the rocker. And on#4the intake valve it was fully backed off out of adjustment. Could you tell me what valve clearance's on the intake valve's are? THANKS
Red Dave
02-08-2006 16:19:09
 Re: 1941 MODEL A POPPING THROUGH EXHAUST . HE in reply to kevin billups, 02-08-2006 13:10:50
Kevin, it sounds like you have found the trouble.
However, in spite of what you may read on the internet, International Harvester says to set the valve lash of your Farmall A at .014 HOT for both intake and exhaust.
Rich Cota
02-08-2006 14:04:27
They should be set at .017-.018 hot. That means after the engine is completely heated up check the valve clearence.
Yugrotcart
02-08-2006 14:49:16
 Re: 1941 MODEL A POPPING THROUGH EXHAUST . HE in reply to Rich Cota, 02-08-2006 14:04:27
.017 hot or .020 cold( both intake and exhaust)
