Any ever pulled a farmall 230??
t.r.y.
02-08-2006 13:47:25
If so how did it do? where does the weight work best and what weight class? thanks
Shaggy
02-08-2006 21:27:34
 Re: Any ever pulled a farmall 230?? in reply to t.r.y., 02-08-2006 13:47:25
There is a KICK BUTT 230 that pulls in the NATPA group. I saw it pull in Ohio just after thank giving and it beat up a few good H's. I think he pulls it in the 3250 and 3500.
ny bill
02-08-2006 16:32:41
i've pulled a 240 several times. it will make the 3500, 4000, and 4500 classes. no extra weights in the 3500, wheel weights and a weight bar behind the seat (over the axle- you sit farther forward on a 240 than a 230)for suitcase wts in the other classes. no traction in the lighter class. upper middle of placings in 4000. 4500 gets into hopped up h's so i don't usually do too well there. i've only had 1 instance where the front end needed some weights, and that was a doozy. i finally stalled it after throttling down too much. i also pulled a super c 1x, but i thought it was geared too high in first for the power it had. both tractors are stock. hth.
migraine
02-08-2006 20:43:24
 Re: Any ever pulled a farmall 230?? in reply to ny bill, 02-08-2006 16:32:41
I pull a Farmall 200 in the antique class at 3000 lbs. Has 11.2-36 23 degree tires and is stripped down to make 3000 including a 200 lb driver. I had the head shaved a bit and valve job but never worked on the bottom end. It really does quite well if I can keep the front on the ground. Usually poweres out and spin out at the full pull mark right next to or behind a neat little AC D-12 that pulls like a bandit. Really fun pulling these little tikes and so easy to haul around. Migraine
