McCormick-Deering Farmall International Harvester?
Gilles
02-09-2006 17:22:40
Wow, What a mouthfull *G*.Looking for carb parts but not sure of model or year.Here's what the plate says...
"McCormick-Deering
Farmall Tractor manuf by International Harvester Co. Chicago Il.USA
Idle speed 1300 No T-14217
Do not overload"
Thanx a million, Gilles
Mike Androvich
02-09-2006 19:08:56
 Re: McCormick-Deering Farmall International Harves in reply to Gilles, 02-09-2006 17:22:40
It's a 1927 Farmall Regular. There are several vendors and/or parts dealers on here that should be able to help you out now that you know what you have.
chadd
02-09-2006 17:41:53
I am not sure but I think it might be a 1925 Farmall Regular or Fairway. Is it all square looking with an exposed radiator, the steering shaft running over the top of the hood parallel to the hood to the front, a semi-square gas tank, and exposed gears for the steering at the front of the tractor above the radiator? If so, I think that I am right. If the steering wheel shaft slopes up from the hood as it approaches the operator, it is a later F series tractor like an F12 or F14. Does it have big housings that the rear wheels are attached to or does it have a long shaft sticking out of the center of each rear wheel? If it has the shafts, it is an F12 or F14. Otherwise, it is a F20 or F30. If it has swoopy sheet metal, then it is a letter series tractor, and will need more information. Hope this helped.
