Farmall H Light Problem
Ryan in PA
02-10-2006 11:51:17
Hi Everyone
I have a 1946 Farmall H Magneto Ingnition. When i was looking to buy the tractor All the lights worked well, So i did buy it and the day we were moving it the starter button shorted out and burned up,Now i went to turn the lights on and none work. I don't see any visible fuse holder on the light swtich like i have seen with some other famrall's Is there a fuse inside? If not did it jsut blow all of my lights out? Where exactly could i find those lights and what model are they?
Thnaks alot!
Ryan
the tractor vet
02-10-2006 12:44:24
 Re: Farmall H Light Problem in reply to Ryan in PA, 02-10-2006 11:51:17
Check and see if the hot wire going up to the box -dash is on the hot pole from the battery ya may have put it on the wrong pole if ya changed the starter button.
Jeff Jackson
02-10-2006 12:08:13
There is a fuse behind the light switch/ampmeter cover which could be blown. I"m not sure what the fuse rating is but you should be able to get it off of the old fuse.
the tractor vet
02-10-2006 12:38:06
 Re: Farmall H Light Problem in reply to Jeff Jackson, 02-10-2006 12:08:13
SFE -20
