ROPS for 350 Utility
jmauss
02-11-2006 09:29:48
In response to an earlier post regarding rollover potential, one of the replies suggested putting a ROPS on my 350 utility, which I think is a good idea for what I am using it for.
Has anyone had experience putting a ROPS on a 350 utility? Are there any aftermarket kits available, or am I going to have to fab something?
Any help you can give me is appreciated. Thanks.
Joe
scotc
02-12-2006 09:51:48
 Re: ROPS for 350 Utility in reply to jmauss, 02-11-2006 09:29:48
why couldn't one be built using the quickhitch mounts? Or run a big peice of strap, like 1/2 by 6 inches, clamped to the axle by the rollbar and running between the axles. It would have to be specially bent and/or welded but why couldn't it work? Or how about mounting an entire structure by using the trans cover mount bolts and having a cage that also mounts up to the bellhousing and front bolster casting? That way you could have limb risers and make it large enough to crush some while not getting crushed youself. I think that'd be the way to go. But I'd also have a good welding or a racing shop(experience w/rollcages) build whatever I came up with.
ny bill
02-11-2006 18:52:50
joe, guy fay's response was exactly what i learned, after getting "reminded" by safety people that my M, Super C, etc didn't have a rops, so any helpers were at risk in a rollover. if you put a rops on and the tractor flipped, an axle could break and leave you worse off. safety people didn't like the thought that rops weren't available for the old girls.
Guy Fay
02-11-2006 15:08:10
Generally, the IH tractors built before 1958 or so are considered unsuitable for addition of ROPS. The issue isn't that you can't build a ROPS for them, but there's really no place to mount a ROPS that won't fracture when the tractor rolls over, leaving you in as bad or worse shape then if you didn't have a ROPS. Contact your Case-IH dealer for info.
Dellbertt
02-11-2006 10:22:29
Ive been brushchopping banks and ditches with my 300u for a long time and never felt like it wanted to go over. But better safe than sorry, you are prob going to have to fab one yourself or maybe redo one that"s about the right size.
