12 volt headlight bubs, price to replace 5th gear.
Chris Gery
02-11-2006 14:59:42
I just bought a 1940 Farmall H. It was converted to a 12 volt system. I'm having trouble finding 12 volt bubls. The 6 volt bubls that came with the tractor are flat on the top. i have tried a bunch of places and no one has any. I'm also looking for a price to replace 5th gear. so if anyone could help me please e-mail me. Thank You
Haas
02-12-2006 13:57:25
 Re: 12 volt headlight bubs, price to replace 5th g in reply to Chris Gery, 02-11-2006 14:59:42
If it has the standard H 4/5th slider gear and that is the problem,new aftermarket ones are available for around $100. However, I just did this a while back on a Super H (The gear is $210 for that)and ended up replacing 5 bearings, several shaft seals (while you have it apart, you will want to do that)and some other items. The parts bill totaled to over $600. This was the first one for me and I am slow, but I figure I spent at least 30 hrs on the job.
farmallhal
02-12-2006 08:04:59
Chris, I checked my M parts catalog and the 12 volt bulb is listed as being no. 1143 with 32 candlepower at 12-16 volts. The 6 volt bulb is no. 1133 again with 32 candlepower at 6-8 volts. I don't know the candlepower for the others listed as back-up lights but are probably some other rating. Hope this helps. Hal
MN Scott
02-11-2006 19:33:32
Isn't 5th gear in an H direct drive? You might need some shift collar or fork work.
I4guy
02-11-2006 19:28:04
about that 5th gear, be sure the gear is engaging all the way. you can check this by taking the belt pulley gear box off and shifting into 5th gear. if it is touching, you can bend the fork to make it engage. be very careful because it does not take much. hope it helps. a lot easier than spliting the tractor. i have done it several times.
tn terry t
02-11-2006 18:25:24
Chris Gery are you sure you need the gear? have you checked to make sure that h does not have a 5th gear lock out bolt?
Kelly C
02-11-2006 16:44:12
Cant help w/ bulbs.
For the 5th gear. Just put a add on this site in the classified ads section.
There are 1000's of H's in salvage yards. You should get about 20 responses with a vierity of prices. Pick the best one.
PAULIH300
02-11-2006 15:35:59
1156 12V bulbs.Single contact.
Janicholson
02-11-2006 17:49:24
 Re: 12 volt headlight bubs, price to replace 5th g in reply to PAULIH300, 02-11-2006 15:35:59
Paul I think an 1156 is a two element Brake/tail light number for 6 volt systems. The corect bulb is much larger and brighter, though it does have the same diameter bayonette base. (I do not know the number)
JimN
PAULIH300
02-12-2006 03:56:54
 Re: 12 volt headlight bubs, price to replace 5th g in reply to Janicholson, 02-11-2006 17:49:24
1156 for back up,1157 taillight,194 wedge base (side marker,licence plate),69/89 single contact small globe,4411 sealed beam 4" tractor lamp,I believe 1034 is the 6V equivalent of either the 1157 or 1156.
Janicholson
02-12-2006 12:50:02
 Re: 12 volt headlight bubs, price to replace 5th g in reply to PAULIH300, 02-12-2006 03:56:54
You are very correct
An interestin bulb is 1183 6 volt It has the flattened dome shape. I went to NAPA to get my bulb screwed in without cross threading.
JimN
tn terry t
02-11-2006 18:19:08
the 1157 is the dual element tail light bulb .the 1156 is the back up light
John M
02-11-2006 15:17:45
While I cant recall the number right off hand, I use backup light bulbs in sevreal of my tractors and they work just fine.Whats wrong with your 5th gear?
old
02-11-2006 15:17:14
I get my 12 volt bulbs from o'riellys auto parts, I never have any problem getting them. Sorry don't have the number of them
RustyFarmall
02-12-2006 05:54:19
 Re: 12 volt headlight bubs, price to replace 5th g in reply to old, 02-11-2006 15:17:14
Old, O'Reilly's is where I found 12 volt bulbs for mine, and they are REAL headlight bulbs. I don't know the number either, the bulbs themselves do not have the number stamped on them. The bulbs that everyone else has mentioned ARE NOT headlight bulbs, they are tailight and parklight bulbs.
old
02-12-2006 08:01:58
 Re: 12 volt headlight bubs, price to replace 5th g in reply to RustyFarmall, 02-12-2006 05:54:19
If some one would post the 6 volt number I could probably remember the 12 volt number. I know its some thing like but not sure, 1146. O'riellys has 2 differant ones also one is flat and one has a curved top but both work well
farmallhal
02-12-2006 08:11:17
 Re: 12 volt headlight bubs, price to replace 5th g in reply to old, 02-12-2006 08:01:58
Rich, 1143 is the 12 volt 32 candlepower lamp and 1133 is the 6 volt 32 candlepower lamp listed in my M parts manual. The MD was a 12 volt system so that is why they are listed in the manual. Send me an email as it's open as I'm another Missouri Farmaller down here in Rolla and Jimmy has mentioned you in the past. Have a good day and it's snowing down here with the wind howling. Take care. Hal
