Super M wide frontend
billin texas
02-11-2006 16:00:07
How can you tell the differance from a factory wide frontend from an after market on a Super M?
Hugh MacKay
02-12-2006 06:57:09
 Re: Super M wide frontend in reply to billin texas, 02-11-2006 16:00:07
bill: I hesitated on this somewhat as I haven't seen all after market front ends. The part that bolts to tractor on IH factory front ends was always cast. I'm not sure about all the after market front ends, but the one's I have seen are fabricated steel. That is the part that bolts to tractor and the axle pivots on.
billin texas
02-12-2006 10:10:32
 Re: Super M wide frontend in reply to Hugh MacKay, 02-12-2006 06:57:09
Thanks for info Hugh. I also found out that IH has a part or cast number about middle ways down the frontend. Bill
billin texas
02-12-2006 09:55:45
JakeF
02-12-2006 18:33:22
 Re: Super M wide frontend in reply to billin texas, 02-12-2006 09:55:45
The factory Super M front will have a cast pivot that bolts to a 5/8" steel plate with two support rods that hook to the frame rails. It will also have tie rods out the front instead of being behind the axle tube.
