Glyptal
CNKS
02-11-2006 17:06:40
My 460 block has been hot-tanked. Do I need to reseal the inside like the factory did, or is that only for new cast iron?
PAULIH300
02-12-2006 11:49:41
 Re: Glyptal in reply to CNKS, 02-11-2006 17:06:40
I believe another benefit of painting the inside of the crankcase is it allows faster draining of the oil back to the pan.A rough casting sort of grabs the oil and it can turn to a sludgy matter if not allowed to flow back down constantly.
kfox
02-12-2006 04:30:30
I have used red glyptal (sp) several times on the inside of engine blocks & transmission housings. There is a better product to use, but its hard to find. Its a red epoxy paint used for motor windings. You might be able to get it at a electriacal wholesaler. It will be pretty "spensive" Painting the inside of engines & trannys keeps the condensate from rusting the cast iron. JMO ken
CNKS
02-12-2006 06:40:21
 Re: Glyptal in reply to kfox, 02-12-2006 04:30:30
Thanks, I'll try to find some. I'm not really concerned about rust on the inside of the block, as the oil, etc should repel any condensation unless it sits a long time (that happens). I was more concerned about oil seepage through the cast, although there is not "standing" oil inside a block.
Andy Martin
02-12-2006 11:54:38
 Re: Glyptal in reply to CNKS, 02-12-2006 06:40:21
I think you answered your own question.
If you are worried about oil seepage through the cast iron, you'll need to paint the inside of the oil galleries.
If it sits a long time, rust on the bore of the sleeves would be a greater concern.
