M overhaul
Leon in TN
02-12-2006 14:06:08
I traded for what I believe is a 1948 M. A buddy of mine had it and was going to overhaul it.When he went to take out the #1 piston the sleeve crumbled and came out too.It has 3 7/8" flat pistons.Can I take out the sleeves and put Super M pistons back in it? If so is there anything else I have to change or replace? This will be my first overhaul project and the tractor will be used on the farm.I want plenty of horsepower without sacraficing dependability.Thanks.
El Toro
02-12-2006 14:36:17
 Re: M overhaul in reply to Leon in TN, 02-12-2006 14:06:08
You can install 4.00" pistons and use stepped head pistons. They have sleeve and pistons kits here on the forum under MarketPlace to your left. Hal
Leon in TN
02-12-2006 14:59:35
 Re: M overhaul in reply to El Toro, 02-12-2006 14:36:17
Thanks El Toro! I just did a s/n check and it"s a 1947 thanks again!
Leon in TN
02-12-2006 14:48:23
