Who makes a 6' pull type rotary cutter?
jmauss
02-12-2006 14:09:37
I started looking for a pull type rotary cutter (540 PTO driven, not one with its own engine). While it looks like most manufacturers make a pull type cutter in 7' and larger, I have only found a couple who make a 6' pull type cutter. One is King Kutter, and another is a company called IM, which I don't know anything about.
Does anyone have any knowledge of who makes the best and most reasonable pull type units in a 6' size? Are there other manufacturers that you are aware of? Or, if any of you know of any new or used units within a couple hundred miles of Eastern Iowa, I would appreciated that too. Thanks, Joe.
Mr. Farmall
02-13-2006 13:08:23
 Re: Who makes a 6' pull type rotary cutter? in reply to jmauss, 02-12-2006 14:09:37
Howse makes 5 foot pull type rotary cutters, I have one for my Farmall A, they used to also make 4 and 6 foot wide ones but I do not think they make those sizes anymore.
Dellbertt
02-13-2006 09:54:06
watch the sales. lots of old 5 and 6 footers out there. I have a 5 and a 6 foot Case.
El Toro
02-12-2006 17:24:55
Call or email Evergreen Tractor at 985-893-3720 or
sales@evergreentractor.com. Hal
billde
02-12-2006 16:52:48
Bush Hog makes a 6 foot pull, the old numbers were 306 and there was a 126. Try Iron Search or Tractohouse.com.
GordoSD
02-12-2006 16:06:39
Woods makes a 6 footer in three different grades. I use the 84 inch BrushBull, has a heavy duty 5 year gearbox and a slip clutch.
Gordo
GordoSD
02-12-2006 16:06:15
Gordo
