farmall 544 clutch or t/a
eddie m.d
02-12-2006 14:11:19
i have a 544 when it gets to pull it will make a noise and act as if it was jumping in and out of gear, i have checked the travel in both linkage, it will also do this when you are moving and and the tractor will coast and take up again, most of the time a sound then the tractor will jump as if you just let the clutch out, it has stoped all together once i pushed in the clutch tryed another gear it moved i put it back in the same gear it worked fine both hi and lo for the hour or two i ran it that day, any thoughts thanks eddie
Jimmy King
02-12-2006 19:56:48
 Re: farmall 544 clutch or t/a in reply to eddie m.d, 02-12-2006 14:11:19
Does it do it with the TA back, if it does it would be the main clutch. With the TA forward, it could be either clutch main or ta clutch.
