Spark plug type
Randy G.
02-13-2006 10:54:13
I need to know which brand and size of spark plug to use in my 1940 H. The manual is no help. Your help is very welcome. Thanks, Randy
Dellbertt
02-14-2006 17:09:41
 Re: Spark plug type in reply to Randy G., 02-13-2006 10:54:13
I have a trash can reserved for Champion plugs.
I switched to Delco C-87 and no more fouling.
Brownie 45
02-14-2006 04:57:00
Champion plugs are not what they used to be. Seems that since they went to C suffix plugs,[copper], problems have cropped up. Last week, I was working on a Hercules generator set. Had good spark on 3 cylinders & nothing on the other one. Took the cap off the mag, suspecting a bad cap. Looked good, cranked the engine over, & had a good spark from the plug wire. Pulled the plug out[new plug] & after much testing, found that it had an internal short somewhere in the insulator[ wouldn't spark at the gap]. It was a J8C. We've been having better luck with Autolite plugs. My two cents worth.
old
02-13-2006 15:30:00
or Autolite 386
sammy the RED
02-13-2006 10:55:22
Champion D-21
