farmall 350, problems to look for when buying
arod
02-13-2006 16:22:21
found a 350 with Farmhand loader at a dealer. Sitting there cause the farmer brought it in for repair, and when given the estimate to fix the problem just let it sit... Dealer tells me they would sell to me.
Has flat rear tires from sitting so long, but appears 100% complete. Gas engine with TA. Not running and I don't know why. But I assume it was just running rough when the farmer brought it in. how does 1,000 bucks sound?
sorry for a "what's it worth" post, I usually only stick to M's and H's.
old
02-13-2006 17:15:13
 Re: farmall 350, problems to look for when buying in reply to arod, 02-13-2006 16:22:21
That might be a good buy or a money pit. Figure if its a TA problem, your looking at $1000-2500 for repair. If it has engine problems say worn out and needs over hual then theres $1000-1500. Now the tires, if they have been flat long then they are probably shoot and thes $250-350 each for tires. That said we picked up a 450 that didn't run and had a loader for $400 a couple years ago and the rear tires where in good shape
Janicholson
02-13-2006 16:38:34
Running rough usually will not cause enough repair bill to cause an abandoned unit. Get the estimate, or have some idea of the issues with this tractor before offering. It probably is worth a grand, but a lunched engine or trans/TA is expensive.
I hope it is just lazyness on the prior owner.
JimN
