STEP
DENNIS ATHE
02-14-2006 19:23:48
I NEED A RIGHT SIDE STEP FOR A FARMALL 656 DIESEL. THIS PART IS VERY HARD TO FIND. CAN ANY ONE TELL ME WERE I CAN GET THIS STEP? THANKS DENNIS.
dagecr
02-15-2006 18:31:49
 Re: STEP in reply to DENNIS ATHEY, 02-14-2006 19:23:48
A right side step was optional on the 666 & 686, one should bolt right up on the 656
James Williams
02-15-2006 15:51:47
I was talking to you over to Billy Knighten.I hope this advice helps you
Eldon
02-15-2006 06:22:37
I have a 1967 model 656 gear shift row crop that does have a right hand step. Certainly looks factory to me. Fenders both have hand hold cutout and bracket around the shift lever and the TA lever both act as hand holds.
DENNIS ATHEY
02-15-2006 19:12:05
 Re: STEP in reply to Eldon, 02-15-2006 06:22:37
HEY ELDON I HAVE THE SAME FEATURES ON MY 656 AS YOURS WITH THE HAND GRIPS AROUND THE GEAR SHIFT AND TA AND I HAVE A PLACE FOR A RIGHT HAND STEP BUT CANT FIND IT. ILL TRY A 666/686 STEP YA THINK IT WILL WORK
Allan in NE
02-15-2006 09:22:31
Hi Eldon,
Sure would like to see a picture of that. Is the right side a "forward-leaning" step like the left?
Allan
Allan in NE
02-15-2006 02:22:12
Dennis,
Boy, I just don't think there is such an animal.
656s didn't have a right step nor a right side hand hold, that I know of.
Allan
DENNIS ATHEY
02-15-2006 19:06:07
 Re: STEP in reply to Allan in NE, 02-15-2006 02:22:12
HEY ALLAN I HAVE THE HAND GRIPS AROUND THE GEAR SHIFT LEVER AND TA ALSO I HAVE A PLACE FOR A RIGHT STEP, I JUST USE A 666/686 STEP IT MIGHT WORK YA THINK?????
IaGary
02-15-2006 04:39:52
I beleive Allan is right. The only ones I've seen are fabricated not manufactured.
They have taken a left step and made a bracket for it.
I got a step waiting to go on a tractor that I will have someday.
Hugh MacKay
02-15-2006 04:36:49
Allan: Your right, no provission for any factory step on the right side of a 656. Couple of threaded holes in the torque tube, wherby one could fabricate a decent looking step. I never did as I installed a cab with steps on both sides. However due to proximity of gear shift lever, throttle lever and hydraulic levers, plus two brake pedals versus one clutch pedal. I'll venture to guess that right cab door got less than 1% of total use. I don't think my being left handed made the difference, as my hired hands were right handed and they did the same.
This was also true of the larger chassis 06, 56 and 66 series tractors even though they did have a bit more room, the left door was still the side of choice. Just look at tractors around the country, paint on grab handles is still in better shape on right than on left.
