Farmall H Drive shaft bearing and countershaft bea
shagle
02-15-2006 08:16:10
Can anyone give me the part numbers for the drive shaft bearing and the countershaft bearing on a Farmall H. Also any tips on pulling the bearings out would be helpful.
Thanks.
farmallhal
02-15-2006 08:54:32
 Re: Farmall H Drive shaft bearing and countershaft in reply to shagle, 02-15-2006 08:16:10
What is the s/n on your tractor as parts change depending on s/n? Do you need bearing part no's. for both ends of shafts or just the forward ones you have been taking apart? You should also replace the pilot bearing in the transmission shaft since you will have it apart. Can't help with removing the bearings and/or oil seals as I've never done one. Hal
shagle
02-15-2006 09:09:45
 Re: Farmall H Drive shaft bearing and countershaft in reply to farmallhal, 02-15-2006 08:54:32
1950 Farmall H FBH 348804 XI.
I will need both sides from the drive shaft and only the transmission side bearing from the countershaft. And the pilot bearing.
Thanks.
farmallhal
02-15-2006 14:03:43
 Re: Farmall H Drive shaft bearing and countershaft in reply to shagle, 02-15-2006 09:09:45
Driving/transmission shaft, rear, ST293 bearing, seal not required on rear. Front, both ST206 and ST247 bearings, 70258D seal and 47894D and 47896D gaskets.
Counter shaft, front, ST246 bearing, 43308D seal and 47873D gasket.
Pilot Bearing, 43356DA.
These part no's. are from my TC-27E Parts Catalog for H and HV tractors as issued in Feb. 1960. Hope this helps and where are you located? Good Luck in your repair, Hal
