jumping dual 6V- 12V system
too embarresed
02-15-2006 08:18:08
Ok, I should know this but am not confidant. When jumping a 12 volt system on an early 70's IH with the series 6 volts. What is the proper way to jump start it with a 12 volt battery? I am assuming I would attach the pos to pos on the batt that is wired direct to starter and the neg to the frame or ground of the other battery. Please no shots I just wanta make sure it is done right
Nat 2
02-15-2006 10:48:02
 Re: jumping dual 6V- 12V system in reply to too embarresed to say, 02-15-2006 08:18:08
Sounds exactly correct to me, too! Ideally, you'd probably be best off going straight to the solenoid (fewest losses just in case the cable is iffy/bad), but since the solenoid is almost never easily accessible, the wire running straight to it is the next best connection.
John T
02-15-2006 08:59:40
So, you sayin someone here would take a "cheap shot" hmmmmm m lol, Im shocked and appalled lol
Best wishes yall
John T (an ex Farmall guy but enjoyed em years back)
Bob M
02-15-2006 08:42:10
You've got it right!
