Farmall H Rear Wheels extension
Ryan in PA
02-16-2006 07:28:53
third party image
AS you can see from the pictures i have a 1946 Farmall H that i bought recently, and the rear wheels are set i think awfully close together becasue the rear wheeels are dished out with a set of wheeel weights. Would it be ok to change them around even to get a maiximum rear width for stability purposes? Waht is the maximum? Also....How HARD is it to get those wheels off? jsut loosen th 2 bolt that i see on the inside? What about the wheels weghts are they hard? The tread on the tires will be going backwards once i do this, but i dont think it really matters?
Thanks Ryan
gene bender
02-17-2006 03:13:15
 Re: Farmall H Rear Wheels extension in reply to Ryan in PA, 02-16-2006 07:28:53
You take the left tire and rim with the center and move it to the right side and then the one on the right goes on the left that way the dish is out and the tires are going the right direction. There is nothing wrong with the way they are now just what are you going to do with tractor. Sounds like you are inexperienced with tractor operation or you would know how to space tread width maybe you should get some help from another owner with an H
NDS
02-16-2006 17:46:59
Good advice but do not believe anyone has mentioned that the 4 bolts that hold wheel clamps can be hard to break loose if they have not been loosened in a long time. I usually have to use lots of penetrating oil and about 4 foot cheater on flex handle to break them loose. Have seen some twist off in clamp before they would move.
CNKS
02-16-2006 14:48:39
Maximum width with standard axles is 80 inches center of one tire to center of the other. Do not try to take off those wheels without help. If you work alone use an engine hoist. Even then they can tip over. If you use a hoist take the weights off first -- unless you are a pro football player. They will squash you pretty good if you slip and fall.
Mike S 806/H
02-16-2006 14:32:37
All of my tractors are that way, I have them set for 28 inch rows, Center of pto to center of tire 28 inch,
P Backus
02-16-2006 09:30:54
Yes, it will be more stable. However, putting the wheels all the way out put quite a bit more stress on the axles and bearings. Paul
williamf
02-16-2006 08:21:23
Others covered the tread direction, you seem to have got that with the application of coffee.
I'm not sure about the maximum width after you switch them around, but it's about 8 feet. As for "How HARD is it to get those wheels off? jsut loosen th 2 bolt that i see on the inside? What about the wheels weghts are they hard?" weel, that depends. Sometimes they come easy, sometimes people write about having to go get their acetelyne tanks refilled. It's a rust and torque thing. The weights are about 145lbs each. After you get them off you'll see that there are 4 bolts on each hub, I think you're not seeing the ones behind the weghts.
Good Luck, and Cowman's right, they look better the other way.
Wm
Ryan in PA
02-16-2006 07:48:11
HAHA I didn't even think about jsut switching the tires side to side....It's Still a little early.....I'm at Penn State University Early in the moring for classes so my geometrics aren';t good yet.....Maybe More Coffe?
What will the maximum width be once this is done with my size axels?
Stan(PA)
02-16-2006 10:37:17
 Re: Farmall H Rear Wheels extension in reply to Ryan in PA, 02-16-2006 07:48:11
A Penn Stater! Me and the wife get down there once in awile. My nephew, Ivan, is at PSU.
Nebraska Cowman
02-16-2006 07:42:58
switch the wheels side to side to keep the tread going the "right" way. A couple tractor pullers here ahave started running their tires "the wrong way" but to me it still looks "stupid"
Nebraska Cowman
02-16-2006 07:40:00
If you have long axles they go out a long way. yeah, just loosen the clamps.
third party image
Stan(PA)
02-16-2006 07:39:11
"The tread on the tires will be going backwards once i do this"
Maybe I"m confused, but if you swap the wheels side to side, why would the tread be backwards?
Ryan in PA
02-16-2006 07:33:02
third party image
Another...v Sorry about the poor quality pics....i had to take them with a camera phone
