Here's some more pics of the 300 5th gear, guys
Levi K
02-16-2006 16:52:20
third party image
Here's a pic of it all the way in 5th gear with the lever all the way back.
Janicholson
02-17-2006 11:19:44
 Re: Here's some more pics of the 300 5th gear, guy in reply to Levi K, 02-16-2006 16:52:20
My two cents.
Put the input shaft and constant mesh drive gear back in the hole. Snug them in. See just how far the fifth gear slides forward into mesh with the splines. if most of its travel is used up befor it engages, the splines (both internal and external are worn from agressive shifting into high. I think there should be about 3/16" of sliding into engagement.
JimN
captaink
02-17-2006 07:20:49
Seems to me that the gear doesn't look terribly bad, I've seen a lot worse that stayed in gear. I would check the shifter forks, centering balls and springs and even the gear shift lever bottom where it goes into the rail for excessive wear to make sure the rail is moving as far as it should.
AJB450
02-16-2006 19:09:24
Levi,
Several years ago my father had an old worn out H that always jumped out of 5th gear. An old IH mechanic told me to try bending the fork so it made more contact with the gear. I did that and the tractor stayed in 5th gear from then on. Saved taking the transmission apart and replacing the 5th gear. So I would check the 5th gear fork if the gears look OK.
the tractor vet
02-16-2006 18:22:24
Show me a picture of the output on the center section and also how much slop is there on the colliar between the fork .
