230 steering
Gary Heglund
02-17-2006 12:39:18
I have to replace the steering shaft and yoke. The key slot is worn on the yolk.The key is tight on the worm shaft but the pin hole is worn.Can I just replace the shaft and yoke? Should I replace the worm shaft also? Steering gear is tight very little play.Any ideas and part# would be greatly appreciated.
SDE
03-08-2009 16:23:14
 Re: Farmall400 in reply to Burl Dudley, 03-08-2009 11:48:47
If you go to www.engineersedge.com you can find the torque value of all grades of steel fasteners. 3/8 is 30 lbs
7/16 is 47
Do you have the correct brass washers and brass nuts? I think they are also a fine thread which will require a different torque value also, which is also on that web site.
SDE
achodges1
02-21-2006 19:16:12
 Re: 230 steering in reply to Gary Heglund, 02-17-2006 12:39:18
Not really sure which yoke you are referring to. I"ve never seen the set up on a 230 but I think it is like the SC and 200. The number in the Super C book for the steering universal joint yoke is 350 256 R1 . This is the half of the u-joint that fits on the worm shaft. Hope this helps.
