330U Governor
Tweeter
02-17-2006 17:52:55
What lubrication and how much gets added in the governor through the fill cap on a 330U?
My 330 seems to move really slow for each gear. I have a Ford 2N with 3 forward gears and 2nd gear on the Ford is like or if not faster and more powerful than 4th gear on my 330U. My T/A lever is pushed forward too. Is that just how these Int. Utilities are? Or is there someting up with my tractor? What gear does everyone rotary mow in?
Harold Hubbard
02-18-2006 06:21:31
 Re: 330U Governor in reply to Tweeter, 02-17-2006 17:52:55
The fill cap on the governor is for the motor oil. It just runs from there down through the timeing case into the crankcase. I should think that the 330 would be at least equal to the Ford in the lower gears. Are you sure the engine is coming up to full speed? I don't have the manual right here, but I think it should run somewhere between 5 and 7 MPH in 4 high. If the tachometer works, or you have or can beg or borrow any kind of test tachometer, the unloded idle speed at full throttle should be about 1750 RPM. Also an old fashioned "RPM counter" applied to the PTO should give you about 540-600 under the same conditions.
I haven't used mine much with a rotary mower, because I am nervous about the PTO clutch, but I knocked down a heavy cover crop of winter rye and clover last fall using mostly 2 high. This was with a six foot rotary mower.
Tweeter
02-18-2006 09:21:33
 Re: 330U Governor in reply to Harold Hubbard, 02-18-2006 06:21:31
I dont have a Tach or any means of borrowing one. Is there some other method that I could try?
